One of the first things I tackled was the lack of AC. I bought a new compressor/condenser kit from RA and put all of that on, along with a new thermostat. This meant pulling everything from the front of the engine forward, which was a bit daunting at first. But, once I got in there everything made much more sense. The hardest part of this was getting the compressors swapped due to Infiniti's Tetris-like engineering. I unbolted the sway bar's end links in order to drop it down and that made all the difference.
Once I mounted and sealed all the new AC components, I realized I had no tensioner pulley for the AC belt. I looked for a pulley online but could only find the other one for the opposite side. Eventually I realized I had an unused pulley on a Honda Pilot tensioner assembly I wasn't going to use and couldn't return, so I bought some spacers and such to get it to sit at the right height when bolted to the stud that I did still have on the car.
Next I rebuilt the power steering pump, which is where most of the leaks came from, I believe. I also replaced the pressure hose just to be safe, and let me tell you...I'm not buying ANY Infiniti engineers a beer anytime soon. When replacing the hose I had to remove the power steering pressure switch from the old hose and transferred it to the new hose, by using a set of pliers to turn the switch while the hose was clamped in a vise. Not ideal, but I couldn't find a small enough wrench to fit under the collar of the switch. Thanks, Infiniti!!
Finally I got everything put back together and cleaned up, topped off all the fluids and bled the antifreeze and power steering fluid. The car's front was on jack stands the whole time, so the power steering seemed to work beautifully while I turned the wheel back and forth to get all the air out. But...when I lowered the car to the ground the power steering wasn't working. I looked around the system and saw no leaks, but I know the pump works because of the way the fluid moved through the reservoir (which I also cleaned out thoroughly, getting the screen hopefully very clean).
I thought maybe it could be the switch, that I possibly damaged it while using pliers on the copper seal. A new one cost me about $90 and had to come from Japan, and that arrived Monday night. I installed it, but when the car started up, still no power steering.
I don't have much experience at all with troubleshooting power steering systems. Can anyone give me a few places to look for possible issues? Thanks!!
