power steering maintenance
Chris Halkides
Car: 1997 Infiniti J30t
Hello Everyone,
My power steering boot is leaking and my shop wants to replace the rack. After doing a search here, I am OK with that (I am a little overweight, and I really don't need to eat for a few months). However, if I put a new rack in, I would like to keep it maintained for as long as possible. My car is a 1997 J30t with 101,000 miles. Since I bought the car about 7 and a half years ago, I have changed all fluids at least once every two years. What else should I do? Thanks.
Chris
qship96
Car: 1996 Infiniti Q45
Dnk plenty of water, take a multi-vitamin, and exercise.
Q45tech
Most systems on vehicles are designed to last 10 years before replacement many survive 12-15 years with good mainteance.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
M1 ATF and a bottle of BG Power Steering fluid conditioner.
Change PS fuid every two years via simultaneous extraction and refill with a BG or Sun (SnapOn) machine.
qship96
Forget the machine based fluid exchange rape and just use a turkey baster to extract old fluid from resivour and refill with fresh ATF....repeat 1x/day for a week and you will have accomplished the EXACT same thing for FREE!
Chris Halkides
Hello Brian,
Thanks. Will I need an alignment also?
Chris
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, as steering links are never exactly replaced.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:Forget the machine based fluid exchange rape and just use a turkey baster to extract old fluid from resivour and refill with fresh ATF....repeat 1x/day for a week and you will have accomplished the EXACT same thing for FREE!
And you will damage your rack when you turn the wheel to full lock and there is no fluid!
There is a reason the machine has a simultaneous fill and extraction, something that cannot be accomplished with even your wife's master turkey baster!
qship96
maxnix wrote:And you will damage your rack when you turn the wheel to full lock and there is no fluid!
Ugh...... Brian, my friend, you do this with the engine turned off.....suck out 8 ounces of old atf and refill with new.....drive for a day to mix.......repeat next 6 days and you have accomplished the same thing as your wallet flushing fancy machine. Just bought 2 quarts of Redline D4 ATF today in prep for this annual routine....and 2 qt Redline gearoil for the annual diff xchange....spent $40 total.
Ask q45tech......this is what he has done from day one til 330,000 miles if you dont think my 222,222 miles {hit that today!} on original PS pump and rack is long enough to prove the method works like a charm. Maybe a study in the law of diminishing returns is in order? Easiest $100{per year} you will ever save on Q preventative maintenance.......I will send you a bill for consultation fees!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I just bought a air/oil pump from walmart for $7 or $14 at sears and Autozone, But anyways I bought it to suck out the PS fluid.
But if i do this is there any risk of air getting in the system when the car is off?
And If I suck out as much of the fluid as I can from the reservoir then refill to the refill point will that work too or should I just suck out 8OZ?
qship96
Paul, take the little strainer/filter out of p/s resivour and suck out all the fluid{ should be 6-8 ounces depending on how full it was} refill with new to correct level.....do this one per day after driving to mix fluid.
No chance of air getting in system as you do all the drain/fills with engine OFF.
Infinitiguy19
Thanks, i appreciate it, I will see if I can get more out since the hose on the pump is fairly long.
Thanks again.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:Ugh...... Brian, my friend, you do this with the engine turned off.....
Then not much is accomplished as you are only skimming the light stuff. Must go full lock to lock with engine running!
qship96
maxnix wrote:Then not much is accomplished as you are only skimming the light stuff. Must go full lock to lock with engine running!
You can go full lock to lock while engine running all you want......heck, go do some figure eights in a parking lot if it will satisfy your OCD, then simply park the car......shut off the motor and suck out the atf and refill with new.....every day for the next week.
Chris Halkides
Hello Brian,
Chris
qship96
Alignment will be needed after rack replacement.
