power steering loss
mortimer9
Car: hunting
Power steering goes off intermittently and the speedometer goes to Omph.Then the power returns along with the speedometer.Fuid levels are OK though did notice some coalessed yellow fluid at the surface.This is a Q45 96,60000mi. What causes this? kevin
1990QOwner
Car: 1990 Q45
It sounds to me like some electrical problem. Maybe the other Q guys can shine more light on it. Good Luck.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yellow PS fluid is burnt PS fluid, so you need to change that..
The problem could be in the instrument cluster... The speed sensitive steering actually gets its signal from the IC, so that could cause that.
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
Or speed sensor itself.
mortimer9
Car: hunting
Thanks for that.Where do I locate the speed sensor and how can I replace it? kevin
