power steering lines
ride4lame
Ok, coming out of my power steering reservoir i have 3 hoses on my sr motor..but the KA had only 2. Where does the extra hose go to? Thanks for the help
~steve
BuudWeizErr
you mean you have 3 lines coming out of your P/S pump?
if so, say hi to your HICAS pump. You get to find a non-HICAS P/S pump, which shouldn't be too hard. Or maybe you can use the HICAS pump, I'm not sure.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
LOL, you always here people saying, "where can i get a SR20 with the super HICAS parts?", and nobody ever finds them, and you get one by accident.
SpeedRacer1
Car: 1990 240SX, G35
Id say trade the Hicas pump (which sounds like what you have) with somebody who needs it for their SR+ Hicas swap.
ride4lame
sorry i didn't get back to you guys sooner, i have strep throat and have been sleeping for the past few days:( anyway i honestly can't tell what i have going on. I think i have more then 3 hoses coming out of the pump, but 3 coming out of the reservoir/canister that holds the fluid. I took a few pics:
Nismo1182
Car: Z06
yup, super hicas resevior and pump.
BuudWeizErr
There are some wires coming out of your reservoir right?
It is a hicas pump/res.
ride4lame
there are no wires coming out of the reservoir...i have a few questions now...is HICAS hard to install? would it even be possible/worth itand are these parts worth alot?thanks
ride4lame
or... is there a way to plug up the hicas parts, then when i find someone to buy them i can switch them? i want this car to run real soon...
Nismo1182
Car: Z06
ride4lame wrote:there are no wires coming out of the reservoir...i have a few questions now...is HICAS hard to install? would it even be possible/worth itand are these parts worth alot?thanks
you will need all the hicas parts and control system, and the rear steering rack. too much trouble to track down good parts. not worth it IMO.
My friends SR came with a hicas pump, the PS bracket was diffrent and the KA pump wouldnt bolt on.
slw240sx
Car: 1990 Ca18det 240sx Hatch
good news is you can modify that PS resivour as a oil catch tank!
240_Keyy
Car: '90 240 Fastback
slw240sx: That is a fantastic Idea!!! I had not thought about using my SOHC PS res as a catch tank :)
Exactly what would I have to do to make that work? just run the valve cover breather hose over to the catch tank and then plug up the second outlet?
BuudWeizErr
Keyy, no, you need to promote flow. From your breather, run a tube to one part of the catch tank, then run another to the spot on your intake tubing. All the oil will come out of the head, deposit in the crankcase and the fresh air will be sucked into the intake.
