power steering lines on s13
jpnissans13
Car: 1991 s13
Ok. so my p/s pressure line broke. it has a tiny hole in it and all the fluid is leaking out. i went online to find a new one. i found in 2 options. and i dont know the difference between them. One has some kind of wire coming out of it and i attaches to the rest of the wire. basically it has a connector/ some sorta sensor i guess.here is the pic of the line im talking about:
and here is the other one w/o the sensor. http://i24.ebayimg.com/03/i/000/d3/2f/639d_1.JPG
will it change if i put the stainless steel one/shiny one instead of the oem one?wat difference will it make if any?
Thanks!!
g35paul
Car: 08 Acura Tl type S, s/c 03 g35 coupe and s13
i also have just found out my PS is leaking too... like i have tiny pin holes in the lines....very slow leak just getting messy under hood now... like to see what u choose to do
jpnissans13
Car: 1991 s13
i have a tiny hole 2 but it is leaking like a *****. i have no p/s what so ever.well if it doesent matter oem or aftermarket i would go with the shiny one aftermarket one.
But idk yet waiting for more ppls advices
g35paul
mine seems to leak bad but maybe just not all the time... i did use some fluid with stopleak in it so maybe that helped some.... im just to cheap to spend the cash to fix it right now... my g35 is in shop right now too and right now it comes first
masterdisaster
Car: 1991 JDM 180SX
little tip for anyone out there... don't use stop leak crap.. i've worked at a canadian tire as a technical advisor for 4 years... stop leak is horrible!
screws up everything else! in 90% of cases
.. quick easy solutions cost 6.99$ + 4.99$
JB Weld + Brake cleaner..
1- drain out the system2- Clean area to repair with brake cleaner and with some sand paper3- mix JB Weld and path her up!!!4- let set overnight
i've used this on sending units, radiators, fuel lines, wiper arms... they have all lasted for over 3 years now and still counting.. execpt for the wiper arms... living on Montreal is hard on them lool
g35paul
awesome man, yeah i usually wouldnt use stop leak but i was in middle of nowhere and is was empty.. was all they had at gas station i stopped at.... it really did seem to work a little, but im probably going to replace all the hoses tomorrow if i can find some nice ones at pick and pull
jpnissans13
Car: 1991 s13
i just ordered the oem set for 100$ nice clean lines with no rust on them!
g35paul
yeah i winning a new set on ebay right now too... junk yard had 3 240sx and all were stripped already
