Power steering line.
Nurokil
Car: 91 240sx Sr20det
Ok this is going to be a real easy question for alot of you but please do. Is the rubber line towards the top of the motor the same as the DOHC power steering line. I have a leak where the rubber line meets the crimp fitting.Thanks all! Much appreciated.ADD: I'm talking about the line that comes from the pump down to the hard lines. I need the soft line from the pump, if that helps any.
Modified by Nurokil at 11:58 PM 10/7/2008
Modified by Nurokil at 11:59 PM 10/7/2008
Nurokil
Seriously, no one knows. I'm impressed, if anyone figures this out please do tell. My steering is shaking because it gets low on fluid so i need this fixed quick.
high flya
Car: 1993 S13 240SX SE Hatchback (Project)
2002 E46 M3 Coupe (Depleting my $$$)
2015 YZF-R3
2011 BL Mazda3 GX Wagon (Beater 3)
Got a pic? HICAS? Your description isn't that helpful. Just keep topping it up with ATF.
Nurokil
Ok I have a Redtop motor. Also have a huge slit in the soft high pressure line that runs Directly from the power steering pump down to the sensor, then into the metal lines. My question is, can i pull this line off a DOHC KA and make it fit with the SR or do i have to pay hundred bucks for a SR high pressure?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
The DOHC pressure line can be used with the SR pump.
