machuelo wrote:Today I found a heavy power steering leak. its look likes come out in the lower side of pulley. I like to know if the pump is repairable or I have to change
Check the hoses and clamps first. If they are intact, you have a problem with the pump. I had a small leak in the exact same spot, but fixed it in like 15 min. There are about 4 bolts holding 2 main pieces of steering pump. I simply tightened them and leak stopped. I think you should try this and see if it gets better. If so, I would take it out, take them apart, clean up, reseal and put them back together. The seal/gasket might have gone bad. There's not much, so it's fairly easy to do. I first noticed power steering fluid on bottom of AC compressor and found the leak was coming from lower side of p/s pump which is located right above AC compressor. I had a leak everywhere on the system. High pressure hose, resovoir, pump...etc, but fixed all of them with no problem. Yeah, tighten those bolts and see if leak gets better or stop. I would go from there. BTW, to get to those bolts, you have to remove a bunch of stuff. IIRC, you don't have an access to one bolt, so just tighten others and see. BTW, NICO member 'babowc' is very familar with p/s pump. You can ask him if you want.
