Yup, exactly. The hose snakes underneath the motor along the power steering rack and attaches to the side of the steering motor with a 22mm bolt. It's a bit of a b**** to do on a TT with the motor in but it definitely can be replaced and is a fairly common problem.marty1mc wrote:I don't think that hose is repairable on the car and I believe you have to pull all the intake/boost (all 3) off the passenger side in order to get to the top bolt. The hose is connected to the PS pump at the top and is visible from the passenger side. I think it's a 22mm head on the banjo bolt.
