evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Jul 08, 2016 11:45 am
Welcome to Nico!
What year is your Z? Are you sure the leak is coming for the rack? Often the hoses or the copper washers at the fittings are the source of leaks. If the leak is at the rack are you running the proper fluid? these cars specify dexron type atf, it much thicker than standard power steering fluid and if you add regular power steering fluid to a system with a small leak it will get much worse fast! Assuming you have the correct fluid and that the leak is coming from the rack itself, take the rack out and take it apart, replace all the seals, basically that simple, there are videos on youtube for rebuilding s13 racks, basically the same process.
