frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Fri Sep 10, 2004 6:01 pm
Ive got a few power steering issues. When I did my ka24de swap into my 90, I got all of the accoding parts to make it possible. When I turned the car on to go, all was well except the power steering pump. It was a 91-93 series to make it compatible with my 1995 engine. It got really hot in seconds so I unhooked the Pressure line and it was fine, except no power steering obviously.
I got a new pressure line, followed the fsm for bleeding the system, etcand turned the car on and werrrrrrrrrrreeeeeeeeeeeeeiiiiiiiiii. The pump worked, and the wheel was sooooo much easier to turn, but it got really loud and hot again, so I shut it off, took the pressure line off again and let the belt run freely again so I could drive the car.
I finally purchased a second power steering pump, changed it out, mounted it, bled the system and I got the same loud whining sound from it. This time, the pressure line is really hard and vibrates when the car is ideling. For now I have disconnected it and have it running freely again.
I believe the pump is getting fluid because when I disconnect the pressure line, fluid leaks from the pump and the line until the resivoir is empty. I am really unsure about what is wrong here. It should be a straightforward replacement/fix. What am I missing?
I am stumped. I have done the procedure twice with two pumps (just because I thought maybe the pump was bad) and have achieved the same unpleasurable result. If anyone can help me out or give me a write up on how to hook up my powersteering specifically, or has ANY idea what could be causing my problem, I'd really appreciate it. I'd hate to sound like a whiney, but I could really use NISTECHs help. Thanks to all in advance.
