wcbjr wrote:This is a new one to me. S13, SOHC. No leaks that I can see. Level is fine. Color is fine.
When I turn left, there is an initial 1/8 - 1/4 rotation that is too easy. Then it stiffens up a bit and the car moves left like it should. Right turns act the way they are supposed to. Why is there a little lag in the steering when only turning left?
Car did this when there was, *gasp*, power steering fluid being used. I changed over to ATF today and the car feels the same way. I have removed the cap, run the car, and turned the wheel lock-to-lock many times now. All of the problems I searched stated that the wheel was hard to turn, not too easy. Any ideas?
These symptoms you mention are similar to when my car's fluid was really low and had a leak. You may have some of the "old stuff" still in the lines causing issues. You might try draining it again, refilling it, and driving it for a while to see if things get better. You might also check the tension on your PS pump drive belt.
