Ex-CA Driver »
https://forums.nicoclub.com/ex-ca-driver-u2453.html
Tue Dec 17, 2002 5:52 pm
OK when I am driving at low speeds, the power stering seems fine, however if I brake from 60 to 10 mph to make a turn or a U-turn, the Steering is very difficult. I have checked the hoses which I am sure needs replacing by now, but no leaks. The res is full, and there is no whining noises coming from the engine. My guess would be either the rack, which I had inspected and was told that all I am going to need are new boots, not a clue as to what they are. And then it was suggested to me that there is a processor or a chip that controls the power steering that may be going bad. Now when i bought the car, the gentleman was extremely far behind for maintenence. I drove th car all the way from Georgia to CA with very little power steering fluid (not my fault, went to the quicky lube for and oil change and they said the filled the fluids. Also on wet pavement the steerign is super and gravel as well. Usually when the tires are wet. Can any one Advise!!:help
