power steering, hole in hardline(how to fix)ASAP
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
skyline2485
Car: 1995 Nissan skyline gts-t
so somehow my hardline from the pump then rubber line then hardline that connects to the sensor was rubbing on my oilpan and now has a hole in it. im in the US so im guessing i wont be able to fine a line easily. is there a good place to check for that, that can ship fast. please someone i need it asap. thankscan i just jb weld it or something like that? or is it too high pressure. thanks.
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
Until you can get a new line, try this for a fix.
What you will need.
1. Two worm style hose clamps that are about the same size diameter of your hard line.2. one empty aluminium soda can.3. If you can find it, a rubber bicycle tire inner-tube patch, but just a small piece. (This isn't necessary, but will help seal things better.)
Carefully remove the top and bottom of the soda can. From the top of the now exposed can, cut down about an inch. Now, cutting around the diameter of the can, make yourself a length of aluminium. It should be about 8 inches long, and an inch wide. Length doesn't really matter as you are going to be cutting off some of the length anyway.
Place the small piece of the bicycle patch over the hole.
Now, take that strip of aluminim and carefully wrap it around the hard line and patch that is covering the hole. Try to keep it as tight as possible so it forms nice and snug to the hard line, and to keep pressure on the patch.
After that, take your worm clamps and place them on the ends of the aluminium patch and proceed to clamp them down. Don't go to tight as you might mess up your threads on the clamps screw.
This should hold you for a short time till you can find a source to get a power steering line.
For that, I would suggest checking the RB forums classifieds sticky or even ebay.
I'll check to see if I have anything off of the spare engine I have.
skyline2485
its the line circled in red.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
If you have a shop in town that can make/repair hydraulic lines, take the line off and take it to them. The ones here (in Austin, TX) can fix the lines when it is the hard metal line that has cracked. Albeit power steering or a/c lines.
Return to “GTR Forum / Skyline Forum”
