power steering help
austin240sx
Car: my car
all right, here is my problem: i am installing a redtop sr into my 92 240. i have the sr power steering mounting bracket. i also have my ka power steering pump. only thepump wont fit on the bracket. so how am i supposed to run the power steering?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
SR power steering pump is the only way to do it, unless you want to make a custom bracket for the KA one...
austin240sx
Car: my car
the sr ps pump has two outlets coming off (plus the resevior) and the ka has just the one (plus the resevior) how do i modify the sr ps pump? also, is there anyone who sells the bracket so that i could use the ka ps pump?thanks-justin
Beau
You have a Super HICAS power steering pump then. The pump (obviously) and bracket are both different. I had the same issue with my SR swap. First you need to take apart the back housing on the PS pump and take out the fan blades so that it is just the wheel alone. Reassemble that being careful with the gasket placement so it doesn't leak. Then you need to find a screw in plug for the second outlet. I happened to have something laying around that fit, so I can't offer any help on what it was that I used. You will reuse your KA pressure side line, but use the brass screw in thing from the SR pump. The line won't line up perfectly, it'll run into the second outlet. You just have to get it on there as best you can.
That should do it. Where did you get your SR from BTW?
Beau
One more thing. The return outlet from the SR pump is much larger than the KA outlet so the hose won't fit. I lucked my way into finding a nice hose at Auto Zone that starts out large on one side and narrows down to the KA size line on the other side with nearly perfect bends in it. I can't tell you what part number or what car it was originally for because the part was laying on a shelf there and had no part number. Make friends with the people at AutoZone, you will need to find several prebent hoses to make heater hoses out of. I had to hack up a couple and plug n play until I found hoses that work almost like they were meant to be there.
VitaminT
Car: 93 240sx SE
Yeah, I had to use a 1/2" to 3/4" coupler to piece together the supply hose from the reservoir (it's not a return outlet, it's a supply line/low presure hose)
VitaminT
Car: 93 240sx SE
BTW...I used my stock banjo bolt to plug the rear outlet and just filled it with JB weld. Kind of gheto, but it seems to work. I also slid my old pilot bearing over it to simulate the hose and also to not allow the JB Weld to leak out the side holes.
Onizuka
My sr from heavythrottle came with a new resevior hose fitting already on the pump, so i cant comment on it not fitting. Maybe heavythrottle can sell you one intstead of having to mess with new hoses and crap. So yeah all my ps stuff just bolted on.
try jspec.com heavythrottle.com sr20store.com and phase2motortrend.com for a used non-HICAS ps pump. You can probably get it cheap from at least one of those places.
austin240sx
Car: my car
thanks for all your posts.....i got my engine from phase2 about 6 months ago, and im almost done!!! well, time to start looking for a ps pump......
Beau
Enjuku told me a non-Super HICAS pump was $450 because the demand has gone up a lot recently due to a lot of Super HICAS SR's coming over here. Let me know if you find one for a decent price.
Onizuka
well, i know sr20store parts out alot of motors so you might really want to concider checking with them before you ghetto fab something.
VitaminT
Car: 93 240sx SE
I agree. You should be able to find something for about $60+sh. Heavy Throttle said one time that they try to hook non-hicus and hicus people up so they can trade.
austin240sx
Car: my car
i say drop the ps. dont need it anyway....lolfinish the car.....
