180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Apr 03, 2006 9:59 am
That wouldn't be the first time I've seen that fitting get stripped. What you can try to do, is this. First get the line in the rack installed then go at the big bolt to the power steering. The hardline does have a flex section if it's the one I'm thinking about and will need some effort to get it around. If not, try loosening the bolt first, where only a few threads are holding the line in place then go at the rack line then tighten the big bolt.
