Power Steering Goes out when speedometer goes out
chuy38
Car: 1996 Q45
Someone answered but my computer crashed. could someone help me out and how to fix the problem. I read something about a speed sensor by trany but not sure can someone point me in right direction.
96Qowner
Car: 1996 Q45
Lino recently had the same problem:
zerothread?id=214882
zerothread?id=228054
It'll either be the sensor or the cluster.
zerothread?id=175418
zerothread?id=143300
bigdog76 wrote:Well everyone on the forum always points to the speed sensor as the problem with the power steering and speedometer failure however i spent $$$$ replacing the sensor and that did not cure the problem. A week after i replaced the speed sensor i replaced the speedometer cluster and puff wa la the problem has been solved now for 4 days no problems at all.
chuy38
Car: 1996 Q45
Where can I get a hold of a manual?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.phatg20.net
FSM and TSB at
http://www.nissan-techinfo.com/infiniti/
for a one day subscription.
chuy38
Car: 1996 Q45
THANK YOU!!!!!!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
My problem has been resolved. I replaced the cluster and everything has been working well ever since.
The speed sensor was already replaced by the previous owner, because of complaints of the same problem. He then returned back to the dealer, bacause that didn't resolve the problem. It was always an intermittent issue and it was the cluster ultimately in my case that was the fix.
Good Luck!
chuy38
Car: 1996 Q45
where and how to replace cluster and where to buy one?
lino
I bought a used one from a person who parted out an Active Q, which was necessary as the Active Q has a specific cluster. You check in the classifieds section here on the forum or ebay.
I used this site to get me started with removing the cluster:
http://www.carstereohelp.com/s...o.htm
then I used this:
zerothread?id=41740
