chuy38https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113power steering goes out when speedometer goes out. 1996 Q45tMon Feb 19, 2007 6:00 pm
Postby
chuy38 »
https://forums.nicoclub.com/chuy38-u57507.htmlMon Feb 19, 2007 6:00 pm
when driving I lose power steering and my speedometer. Then after awhile it comes back and power steering comes back sometimes stays off for awhile. Can anyone help me?
Postby
Q45tech »
https://forums.nicoclub.com/q45tech-u112.htmlTue Feb 20, 2007 5:25 am
relay?......................solenoid
The speed sensor sends a signal to an IC [mounted in speedometer housing] which sends speed signals [0 to 5 volts] to TCU, PS pressure controller, the ecu, and the actual speedometer [voltmeter].
Other than bad wiring, the most common failure is the speedometer assembly itself [the part that creates the 0-5 volts].
