Kellsonm »
https://forums.nicoclub.com/kellsonm-u244150.html
Mon Mar 09, 2015 9:58 pm
Hey everyone, so I've had my '01 QX4 (160k now) for a few months and it's consistently had this problem where a very loud screeching sound comes from the engine on startup. The problem gets worse as temperature decreases. If it's above 60 degrees outside or the engine is already warm, there is no sound. Also, the sound changes when the steering wheel is turned. A visual inspection of the accessory belts reveals only very minor cracking. All of this leads me to believe that the sound is coming from the power steering system, and I've heard the sound may be a result of air trapped in inside the system, possibly a result of bad "o-rings in the hoses".
Has anybody had/fixed this problem? I need some more information to determine the best way to take care of the problem.
Thanks!
