Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Sep 27, 2002 7:41 am
The color of ATF is red [dye] by convention and PS doesn't need to pass the slick/slip test of clutch lockup as ATF does so PS can be produced less expensively.But the SAE specs of the base product [without ATF dyes and additives] are equal.
If heat wasn't a problem with PS why would all cars have PS coolers......look around you'll find extra convoluted metal tubing in the circuit sometimes an actual finned cooler!
On a Nissan we use the ATF for both as it is a stock [inventory issue] and the 20 cents per quart lower cost is not significant vs keeping two types........it costs us about $275 more per year to use ATF vs a dedicated clear PS fluid not accounting for floor space, pumps for 55 gallon drums, and ordering costs.
