Power steering fluid
KatsJ30t
Car: 1993 J30t
Hello,My daughter just bought a '93 J30t (only 76K for $5K seemed like a pretty good deal). The HICAS light has flashed a couple times and I read on the forum that it most likely needs power steering fluid added. From looking at the PS reservoir dipstick that appears to be the case. One source we found said to use Dexron II, which does not seem to be commonly available where we are. In your experiece is Dexron III (which is easier to get) OKor do you have other suggestions? Thanks for any help!
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
this system is sensitive to the type of fluid used, i suggest calling the dealer and see how much they charge
