Power Steering Fluid - PSF or ATF
humuju
Car: 2009 Infiniti G37 S
I understand it's best to just follow the recommendation. However, the manual for my G37(S) 2009 says "add Genuine NISSAN PSF or equivalent". The cap on the reservoir says "ATF Dexron". So which one should I use? Also I assume if it's ATF then Dexron II and Dexron III are both ok.
On Amazon I also found "Genuine Nissan Fluid 999MP-EPSF00P Electric Power Steering Fluid". Is there a difference between ELECTRIC PSF and just PSF? Or do they both mean the same? It that 999MP-EPSF00P what the manual refers to with Genuine NISSAN PSF?
centralcoaster33
Car: 1997 Nissan 240SX #5
Dexron VI is the equivalent of Genuine NIssan PSF according to the Factory Service Manual. Looks like Valvoline makes it for an off-the-shelf purchase.
humuju
Thanks a lot. After your post I googled the Factory Service Manual and it pointed me back to NicoClub.com :D. I ended up buying Valvoline DEXRON VI Full Synthetic Automatic Transmission Fluid. Amazon also had Mobile but that one is a blend which is probably ok. I didn't go with the Nissan one (999MP-EPSF00P) because it's Electric(!) Power Steering Fluid and I couldn't find and 1 quart (hydraulic?) PSF.
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
Is this right?
https://www.valvoline.com/our-products/ ... ron-vi-atf
Dealer says I have a rack leak but reservoir is slightly above the max cold level. Not sure if they filled it during my oil change, will watch for a few months.
Is there any benefit to replacing the fluid in the reservoir with turkey baster method a few times? I had it flushed at independent shop 15K miles ago.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
humuju wrote:
Mon Oct 30, 2017 7:52 pm
Good move. EPS is only for electric pumps. I don't know what it would do to a Dex6 system, but I know for certain that Dex6 makes a mess of the electrics. So my bet is it wouldn't go well.
muscleOHV
Car: 2008 Nissan Altima 2.5SL crashed 188k miles
2012 Infiniti G25 with 115k miles
1999 Chevrolet Silverado 5.3 218k miles
Question:
In the past on my Altima, I just drain out PS fluid from resevoir, and put in new fluid
Jack up the car, start up the car, then turn the steering wheel left and right.
Is that a good procedure?
muscleOHV
Question:
