Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Tue Sep 10, 2002 1:16 pm
There's a huge maze of p/s hoses under your Q. If you've never replaced the hoses in and out of the fluid tank, I'd check there first. Best thing you can do is get the car up on stands or a lift. Clean everything up with brake parts cleaner, start the car, have someone turn the steering wheel to the stop, and look for the fluid. Never keep the wheels to the stop for more than 10-15 seconds. If it's a high presure line, you'll see it dripping or squirting out. Hoses in and out of the tank will be oily and grity, but probably won't squirt out fluid.
Heath
