Power Steering Fluid in my PS reservoir? Shouldn't it be DexIII (ATF)?
ascdesigns
So this is slightly disturbing... When I went to check fluid levels, I noticed that the PS fluid is golden, not the translucent red transmission fluid. The manual calls for DexII/DexIII (or equivalent).
Has anyone ever had issues running PS instead of AT fluid? Should I flush the entire system asap? I also notice a few very, very fine metal filings in the filter 'cup' - almost looked like silver dust.
FWIW, my steering has been working perfectly, no groaning, stiffness or otherwise arthritic symptoms.
If I need to do a flush, how many quarts of ATF DexIII should I purchase?
Thanks!
Al
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The ATF is just worn out, its still ATF but the system TOTAL only holds about a quart, with the res. holding about 1/3 of a quart at the most.
IMO the easiest way to change the fluid is to just suck the fluid out with like a turkey baster, replace it to level and keep doing it like every day for a week and it will be nice and red...
ascdesigns
Thanks elwesso. I don't think it's worn out though. Old, tired ATF looks dark red/brown, not the honey-gold color like new/good PS fluid.
Nevertheless, since it takes a quart, I may just flush it out by doing the "lock-to-lock' method with the return hose in a small container. ATF is a little thicker than the PS fluid (or so it seems) and I think it has better seal conditioners.
I'm still open to opinions though.
Thanks,
Al
elwesso
2007 BMW M Coupe
that works too and would allow you to change the fluid in one session....
Ive run PS fluid and ATF and I cant really tell much of a difference to be honest, so I dont know if its even worth changing?
W O T
Car: 2001 Infiniti Qx4
I stick to ATF in my PS system, just easier to have a big 20 gallon jug of ATF, flushing it is a breeze with a turkey baster
ascdesigns
Thanks all. I did flush my system tonight with a synthetic blend DexIII. Really easy to do, just a bit messy. It's amazing how quickly the PS pump pushes out the fluid. In case anyone's interested in how I did it, here's the basic steps:
- Jack up front end and place on jackstands. You want to be able to turn the wheels easily.- Drain the reservoir as much as possible using a 'turkey baster'.- Pull the return hose and plug the nozzle on the reservoir.- Attach a male-to-male barbed fitting into the return hose.- Attach an extension to the other end of the barb fitting and place it into a milk jug.- Fill reservoir up the top with new ATF fluid.- Start car, wait two seconds and turn it off. Any longer and you'll be sucking air.- Fill reservoir again.- Start car, wait two seconds and turn it off. Again, any longer and you'll be sucking air. - Fill reservoir again.- Inside the cabin, turn the steering wheel all the way to the right. Hold for a few seconds, then do the same for the left. Repeat. This exercise pushes fluid through and out of the system.- Add more fluid to the reservoir.- Do the steering wheel exercise again, but this time leave the fluid level lower since you'll want to put the return hose back on without fluid gushing out of the reservoir.- Clean everything up, reconnect the return hose to the reservoir nozzle, lower the Pathy. - Top off the reservoir now that the return hose is back on. - Start the car, turn the wheels side to side. Check the levels again (I had to add a couple ounces before all was said and done.)- Get a beer.
Cheers!
Al
Pwnin O'Brien
Why is it that the FSM suggests ATF for Canada only? I don't get it.
W O T
Viscosity @ -40 would be my guess
