power steering fluid change?
captainluigi
Car: 1996 q45t
how do i change the pwr str. fluid? might as well do em all. thanks all.
redmanfx
Car: 92 Q45a
Two ways to do it. The way I'd suggest is to remove the hose from the pump and reservoir and let the fluid drain out. The pump has an in and out hose, so you can get it fairly empty. The other way I here about is the Turkey baster approach which is inserted into the reservoir and sucked out.
Only use oem power steering fluid for the Q or mobile 1 transmission fluid. Nothing else is worth the promblems you'll get from using it.
red
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Highly recommend the mechanical extraction replacement (if fluid not brown) or the full hook-up mechanical flush if it is. Sun and BR make such equipment. Wynn's has something also, but I am not familar with it.
Look at Scott Jackson's post in Infiniti Mechanic Forum also.
captainluigi
Car: 1996 q45t
thanx to all. im flushing the trans manana so maybe they can do the pwr. steer., also doing brake fluid & diff. that only leaves coolant, seems ok but will change for peace of mind. got some steering rack boots from napa but the small end orifice, hole,whatever seems really small, like maybe only3/8, i didnt measure but it sure seems a big stretch to fit over the tie rod ends. i hope the mech. will know for sure. looking forward to that 1st road trip after i feel confident about everythig.
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
I used the turkey baster method over the course of a month to make sure I got all the old out. Definitely use MOBIL 1 transmission FLUID!!!!!!!
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
Just stopped by the Infiniti dealership today and inquired about a full P/S flush. $200+ !!
I think I will stick with the turkey baster method.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
U
captainluigi wrote: got some steering rack boots from napa but the small end orifice, hole,whatever seems really small, like maybe only3/8, i didnt measure but it sure seems a big stretch to fit over the tie rod ends. i hope the mech. will know for sure. looking forward to that 1st road trip after i feel confident about everythig.
Uhhhhhhhhhh (in my best Butthead voice) you're supposed to take the ends off first ...... heh heh......
redmanfx
Car: 92 Q45a
I would really take the hose off the PS pump as well to drain as much Old fluid out and not just the Turkey baster method. The pump holds alot of fluid that you don't see. Just jack up one side to get under there and you can take that hose off easily. Just my humble opinion though
red
