l0nestar »
https://forums.nicoclub.com/l0nestar-u38221.html
Mon May 14, 2007 6:45 pm
Alright. I'm trying to fit a cooler of some sort on my power-steering system in my S-13. I am using the R33 X-member. I think that I have a solution picked out, but I'm interested in what everyone / anyone has. I cannot use the stock S-13 (Dohc) cooler loop because I'm using the R33 unit (and I do not want to bend the crap out of it.).
What I am thinking of using is a small power-steering cooler from a Jeep and various Dodge vans as the heat-exchanger, the ends from the S-13 loop, and some power steering (low pressure) lines with hose-clamps of some sort. The cooler has 5/16" ends as well. simple 2-pass with fins. Core dimensions are 6" long x 2" wide x overall length is 8.5". Run the hard-lines from the S-13 rack over the x-member, and then use the PS hose and interface the cooler then back up to the res like stock.
Again, interested anyones suggestions or solutions THEY found / used. I'm not 100% sure that I absolutely _MUST_ have a cooler, but I plan on doing 'spirited' driving and I know it is a good idea to have _something_.
I can clean up my thoughts tomorrow. I'm sleep deprived at the moment.. Thanks for listening !
