I read many suggestions on which lines to get for power steering to work on 89-90 models. Some says to get all the lines from 91-94, some says just the high and low pressure lines. But I was reading heavy throttle's web site and heres what they have to say"Since the KA engine was DOHC, the power steering bolts right on with no modifications. If using a SOHC chassis you will need to buy the high pressure 91-94 DOHC power steering line and reservoir to make the power steering work, or have your SOHC line cut and brazed to the rack end. "
http://www.srswap.com/faq/index.aspso which one do I have to get. I have the whole front clip so I should be able to use the reservior and and pump right? if so then this should work for high pressure?
http://www.partsamerica.com/Pr...92098and this for the low pressurehttp://
www.partsamerica.com/Pr...91517and yes I have search and read every topic about power steeringThanks in advance
