Power Steering Brackets Interchangeable?
FTRS14.5
Hey,Does anyone know if the S13,S14, and S15 power steering brackets are interchangable? Thanks in advance!!!!
Cyberkreig
Car: 1993 Nissan 240SX SR
i'm sorry that i cant give you an exact answer, but i can tell you that the bracket bolts to the block, and all the blocks are identical..
Now if the pumps are different.. or bolt to the bracket differently i cant say
FTRS14.5
Well, thanks for the info you have!! So you think a S14 KA PS Pump with a S15 PS Bracket bolt onto a S13 Block?? Hahaha!!If all the blocks are the same, then it should work correct? Other than pulley size of the KA, but everything should just bolt on right?
Cyberkreig
I can only speak from hearsay.. which is that the SR/KA pumps are all the same except for the pulley.
I've never seen an S15SR block in person.. but if its an SR block, its an SR block..its a gamble i'd feel OK about taking
FTRS14.5
Alright, that's what I was thinkin too. I did a search and found some info about a S14 KA PS Pump and a S14 SR Bracket working on a S13 block. So thanks a lot for your help and if anyone else has something to add to this, it would greatly be appreciated. Thanks!!!!
SpeedRacer1
Car: 1990 240SX, G35
The pulley on the S13 and S14 SR pumps are different widths.
