ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Sat Feb 10, 2007 7:39 pm
I'm with him. The pressure solenoid is down on the steering rack itself and two bolts hold it on along with 2 wires that are plugged into a harness. You can hook up 12V to the pins in the wiring harness with little jumper wires and if it clicks, it's probably fine. Is the power steering by chance working fine when it's cold but sometimes after it's been running a few minutes it gets very hard to turn like the power assist just shuts off? Mine did that and I did a lot of digging until I finally found that the spring loaded pressure regulating plunger inside the steering pump was sticking at times and bleeding off all the pressure. The fix was to pull off one steering line from the pump, start the motor for a split second (shoots fluid out along with the little plunger and spring), then lightly sand the edges of the plunger so they wouldn't catch the bore it goes in, and then put it back together. As for the pressure module, it's in the dash just to the right of the steering column and what normally happens when that fails is the steering assist will cut out and come back in at random when you hit bumps. Firmly smacking the dash with your hand will produce similar results. What happens is the solder points on the circuit board inside the module crack and lose connection.
