Power Steering Belt
efroubi
Car: 1997 Infiniti J30t
I'm done.. enough is enough!
My power steering pump is extended as far as it'll go and she still squeals on a cold startup. Power steering resovior is full. This is my 2nd belt.
Is it safe to buy a belt a size or two smaller? Any recommendations?
Thanks
MikeRL411
Car: 1997 Infiniti J30T
1967 Datsun RL411
Go OEM for replacement ! tHESE ARE VERY SPECIAL v6 ENGINES.
efroubi
Thanks! I will try an OEM belt. These Gates ones are crap..
macgiver
mac here, also measure / bring along the old belt and see what's up with the " end of the adjustment deal" ,do get preferably an OEM and if for some unexplainable-weird reason :tisk: it truly needs to be "smaller" GET a SMALLER belt because a replacementpump (may have been installed ), which may be fine, probably has a smaller diameter PULLEY ! :rotfl So ,in that case you gotta try - should work - the correct "New" ,but smaller :yesnod size ? Don.'t forget to "brakleen" wipe all the associated pulley "grooves" . Glen 11/18/2017 :cool:
