power steering belt rb20
xdream
does anyone know if any nissan belts are interchangeable with the rb20? i need a rb20 power steering belt asap. can i buy something at autozone that will work?
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
Thats exactly what I did.. brought my old belt to autozone, compared it to another one there, works perfectly.
xdream
damn too bad i dont have an old one! do u remember which model u ended up buying?
AxiOn419
No I do not, I can take a look when I get a chance later. I will see if there is a part number on the belt somewhere.
There are posts about this though, so I am sure you can find a belt that will work. Check the stickies or try searching, I know its been discussed.
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Alt- K040335A/C- K040358P/S- K030328
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
nizmo zilvia wrote:P/S- K030328
nope. on my rb20 that belt didnt work at all, it only had 3 ribs and was way to small.
now you seriously could have found this out without posting a new thread, its right there in the sticky under rb replacment belts.
but im not a d!ck like alot of people on here so im flaming you, AND i will also answer your question to.
these are the belt part numbers from napa
alt- 040335p/s- 040372
i didnt get a ac belt cause im not running it.
xdream
thx so much.. i did search but not there.
xdream
yo those napa number dont work.
AxiOn419
Did not have a chance to work on the car yesterday, today I am so I can get that belt # to you if you need it still.
xdream
ok new problem i cannot get my power steering pump to stay in the adjustment mode i want. it just sits all the way down. am i missing some screws or a bracket?
driftmyke
xdream wrote:yo those napa number dont work.
because whoever helped u at napa is a retard, ask for a manager to assit you i qarantee they can get them.
xdream
hey can someone help please. how do the adjust the belt tension on the power steering pump. my is just able to move up and down??
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
your missing the adjustment bolts
xdream
well i got it to hold... there is a bold that u can get to thru the pull. i tightened it all the way down in the position i want. dunno if thats the rite way or not but it seems strange to me to clamp it with the same bolt it pivots on.
but any it works.
ahah and after 7 trips to autozone i finally got a hose that fit.
it was a 4 bar 945mm belt. lol
everything works perfect.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
k... 4 925 or something for ps I believe :-)
I posted the numbers somewhere, check my posts
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
How are the custom power steering lines working for you. I'm replacing my pump, rack, and tie rods and was wanting to do the custom lines. You got any part numbers on the Earl fittings to use?
onepuff
ripracer
Yes that is the write up I'm using just wanted to see if a rb20 guy was using the same part numbers.
I have an order ready with summit to do pump to rack, rack to cooler(thinking about using a transmission cooler?) back to resv.
