petersm »
https://forums.nicoclub.com/petersm-u131.html
Wed Aug 27, 2003 11:35 am
The power steering on my 91Q remains in the full assist mode even at highways speeds.
The tech at the Infiniti dealership has checked the resistance on both the PS pressure solenoid and the control module and they both check out within spec.
The tech said he has never seen this problem before, usually you lose assist. He thinks it might be a stuck or damage pressure regulator value in the aftermarket rack. Tonight he is going to check the pressure in the PS pump.
Your thoughts, thanks
Marvin
