FRSport »
https://forums.nicoclub.com/frsport-u51641.html
Tue Apr 24, 2007 11:10 am
I suggest you do more reading on turbo's (turbo books - a good start is Corky Bell's book, the FAQ's on this forum & other forums).
You don't fix a "running rich" problem by upping the boost. Bad idea. You fix it by tuning it correctly for the boost level you want. Please do not be one of those kids that knows absolutely nothing about the car, buys it, then blows it up due to inexperience - read as much as you can first.
The power steering problem, could be a number of things, but the hi-pressure hose likes to leak on our old cars - that's about a $50-100 fix depending on the line you buy and if you do your own work. Of course, it could be leaking from the rack or somewhere else - you have to either check it out yourself or have a mechanic look at it.
