rbosacco »
https://forums.nicoclub.com/rbosacco-u41320.html
Sat Mar 03, 2007 4:10 pm
well... i have plenty of clearance on the steering shaft. a whopping 6mm! the truth is that the steering works fine when not under a huge load in my opinion. if you guys get in your cars and turn the wheels as fast as you can to either side does it kind of bump up against the limitations of the power steering? there might be nothing wrong with it maybe i am asking too much, but a friend of mine has a stock 93 coupe that he drifts and i've driven it and it steers so much better than my car, you can just whip the wheel either direction as fast as you want, with no resistance. that's what i would like to get my steering to act like. and it is definitely not a idle problem it does it at all rpm's. is line length an issue on power steering? when i made my lines i shortened alot up it really cleaned up the engine compartment down lthere. i might just be retarded.
i'm just looking for other perspectives on a solution. maybe i need a new pump. i dont know.....
