cmkelly wrote:Thanks, I just checked and it is a little low. I haven't seen a leak however but I'll be on the lookout. Some paper towels on the garage floor tonight should do the trick. So far I've been lucky, she doesn't leak any fluids.
cmk
Good. Okay, do this. Add PS fluid to full and turn your wheel all the way to the right or left and stay like that a couple of sec. It's not a good idea to do that, but you can check your high pressure hose that way. Mine leaked only when I do that and I found a crack on HP hose.
Another one. PS pump has 2 main pieces bolted together with 3 or 4 bolts. Check the spot between those 2 pieces. I also had a leak there and tightening the bolts fixed it.
