I own a 2003 nissan altima 3.5,Just had timing chain & chain tentioner replaced about a month & n a half ago.Seemed to be doing fine up until lastnight.I was backing out of my driveway & as i stopped to put into drive i then turned the stearing wheel slightly to take off & heard as well felt a loud & hard thump,so then as i began to pull forward i then noticed i had no more power steering,i parked it to investigate the problem and of course the long trail of power steering fluid.so i refilled the power steering started the car had friend slowly turn steering wheel back n fourth so i could try & locate where the fluid was leaking from.I noticed a drip from the passenger side but then I noticed a large flow of fluid leaking from the driver side,it was coming from the cv joint.I would very much appreciate any advise about this.
thankyou
