Plankton »
https://forums.nicoclub.com/plankton-u21164.html
Tue Jan 03, 2006 3:53 pm
A few weeks back, I posted a post talking about how my power stays on with the key out of the ignition, I noted that a few of my fellow members were having the same problem. I recently fixed this problem on my car, and I would like to drop some knowledge to possible help a few members who are experiencing the same problem.
Option 1: In the front of the car, where you plugged the harness in, there is a brown plug. You will see a thin red/black wires there. Make a small opening in the insulation, take any other wire and when everything is lugged in, ground that red/black wire to the negative side of the battery. You should hear a click.Option 2: Jump the black/white wire on the grey plug(next to brown plug), to the black/red wire(brown plug); and cut the black/white wire from the plug.
