xsdg »
https://forums.nicoclub.com/xsdg-u227699.html
Fri May 09, 2014 10:52 am
Is it an automatic or a manual? Are you always seeing problems right around 35mph, regardless of what gear you're in, or does it seem to map to a particular RPM, or does it only happen in a particular gear (or a particular couple of gears)?
That said, a few things come to mind: if the float isn't set properly, that could cause fuel starvation. Also, if there's crud in the fuel lines, then that could restrict your fuel flow even with a new fuel filter. From what I've read, the fuel pumps tend to last pretty long on these trucks, but a bad or worn fuel pump could also result in lower-than-normal max fuel flow.
