matttail »
https://forums.nicoclub.com/matttail-u50105.html
Thu Jun 14, 2007 6:05 am
To the OP, the manuals says "Avoid using power outlets when the airconditioner, headlights or rear window defroster is on." You might want to at least be ready to tell the dealer that's not the issue.
As far as power to that plug goes, the manual also says that the plug is rated for a maximum of 12Volt, 120W (10A). So your 75W laptop converter should be just fine. You may well be able to draw more than that, but the problem is that you're start overheating the cables running power to the plug and they may melt and burn. Not good.
