fb9821 »
https://forums.nicoclub.com/fb9821-u67722.html
Tue Jun 12, 2007 5:14 am
Sorry havent checked for codes, waiting to get a referral for a good Z tech, dont want to take a regular shop where these guys may experiment. fuel filter has not been changed in a long while, thought about doing it but then figured that if it was that, the problem would be consistent at various speeds and rpm. this problem is troubling cause it only occurs when you pull the gears out. i will change the fuel filter anyway, cause that is the first suggestion that comes to mind. thanks for your help and if you figure anything else let me know.
