Power Seats
q45t96
Car: 96 Q45T
I realized a couple of months ago that my front seat and the steering wheel stopped moving everytime I turned of the car. I checked the fuse boxes and owners manual and could not find a fuse that I could connect to this function. Does anyone have any idea why this function would stop working. All of the motors work fine to move the seat and steeing by the controls. I have a 1996 Q45t with 107,000 miles. Thanks for your help
Rex
Car: None
Did you disconnect your battery at any time? I think this function has to be programmed/re-set. Mine didn't do it the one time I tried to after I dis-connected my battery as part of the fuel pump replacement.
We discussed this and the tilting side mirrors, when the car's in reverse a couple fo weeks ago.
PalmerWMD
Car: 2004 350Z
Check your cancel switch for that function.It's on the left of the steering column right next to the stalk ofr the light switch.
90% of the time when folks complain about that function not working, they inadvertently depressed the cancel switch.
Fred..:)
q45t96
Car: 96 Q45T
Thank you. I hadn't ever noticed that button before. I works perfectly now.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I hit that button with my leg all the time......
szh
Car: 2018 Tesla Model 3.
On a similar note, a friend's wife was once complaining that the memory button on their 93Q was not working anymore. She would push 2 (after the friend drove it and set it to 1) and nothing would happen. I asked her if she had had the car engaged in gear when she tried it ... problem fixed! :D
Z
