Power seat won't move back when I take out the key...
qsiguy
Car: 1994 Infiniti Q45 Turbo
This feature has always worked fine except one other time. This time my battery went dead and now my power seat and steering wheel doesn't move back when I take out the key. Seems like this happened to me once before but I can't remember what I did to make it work again. I thought I just needed to put a setting back into the seat memory so I did that and it does work but the key activation still doesn't work.
Anyone have any tips on this? Is there a way to turn this on/off?
Thanks.
gkdada
Car: 1992 Infiniti Q45
If the '94 is the same as (my) '92, there is a button right next to the tilt switch at the base of the steering wheel to turn this feature on/off.
cheers
-Gopal.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Common after you remove the battery... Simple fix.
open the drivers door, put the key in the ignition (dont turn it, just shove it in) and open and close the door a couple times. Done.
qsiguy
You da man Wes! That did the trick.
