power seat problem
2000 bamamax
my back and forth motor in my power seat is bad.where can i get that one motor from? The dealership wants $900.00 for the whole kit ,plus labor. Any help would be helpful, thanks. oh by the way it`s a 2003 g35 sedan.
zozoka1212
Car: 08 Infiniti G35x
Local junkyard would be your best bet. If you can't find one there is online usedparts store(junkyard).
zozo
zozoka1212
http://car-part.com/cgi-bin/search.cgi
$500 for the whole seat and the airbag plus the track.Down the mid page somewhere.
zozo
joe603
Car: 2014 Durango R/T
Are you sure it's the motor and not the switch??
My switch broke on my 05 coupe...Did you just get a quote from the dealership or did they troubleshoot the problem and tell you that you need a new motor? A switch is a hell of lot less expensive than a replacement motor!
2000 bamamax
well every time i use the switch i hear the relay click. Also it was a quote from the dealer
telcoman
2000 bamamax wrote:well every time i use the switch i hear the relay click. Also it was a quote from the dealer
bamamax
Welcome to NICO
It could be a dirty contact or a defective relay? Or it could be the motor? A shop manual with the electrical schemetic would assist you or you could pay the dealer to pin down the defective part? It's just battery and ground.
Good luck
Telcoman
504G
Car: 2003 G 35 Coupe
Dude my G is at the dealer as we speak for the same problem! My pass seat would go forward but no back! It was the switch in the seat and costed $200.00 plus labor! Only done fall I havent seen my G In 3 days. Not because it takes that long but because UPS lost my switch at the warehouse!
Good luck!
2000 bamamax wrote:my back and forth motor in my power seat is bad.where can i get that one motor from? The dealership wants $900.00 for the whole kit ,plus labor. Any help would be helpful, thanks. oh by the way it`s a 2003 g35 sedan.
