Power seat problem (passenger side) I35
nemesismax
Car: 2002 I35
The power seat on the passenger side of my car doesn't move forward and back. It will lay the back of the seat down and lift it up but do nothing with the actual position. Is there anything anyone can suggest?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
It could be jammed. Check the track for coins/pens/etc.
tomc
Car: 2001 Infinity I-30
If there is nothing mechanical interfering with the operation, try this: there is a motor under the seat which, if you tap on it lightly with a hammer while operating the switch, will start working again--or at least it worked for me (either seat). I learned this on the forum several years ago when at the point of replacing all that mechanism.
tigersharkdude
Car: 1999 Nissan Maxima
possibly the plastic gear is "broke"
heyjude
Car: 2002 Nissan Maxima GLE
Did you figure out this issue, and if so, what was the resolution? I have a 2002 Maxima that has the exact same problem, except mine is the driver seat.
Thanks.
nemesismax wrote:--------------------------------------------------------------------------------
Daddygonz
Car: 2010 Ford Mustang GT
04 Infiniti G35 coupe
04 Roush Focus
02 Infiniti I35
94 Chevy S10 PU
91 Volkswagen Golf GTI Mk2 16V
90 Camry
86 Nissan 300ZX
My 2002 I35 driver's seat went out and it cost me $600 to fix at the dealership.
heyjude wrote:Did you figure out this issue, and if so, what was the resolution? I have a 2002 Maxima that has the exact same problem, except mine is the driver seat.
Thanks.
heyjude
Do you know what they replaced? I would prefer to do it myself and would like to get some advice on things to check.
[quote="Daddygonz"]My 2002 I35 driver's seat went out and it cost me $600 to fix at the dealership.
[quote="heyjude"]Did you figure out this issue, and if so, what was the resolution? I have a 2002 Maxima that has the exact same problem, except mine is the driver seat.
Thanks.
[quote="nemesismax"]
tigersharkdude
Just wondering if you ever looked to see if your problem was the plastic gear? Those gears can get very worn and stripped, or possibly break
