power seat not working!!!
crazyboy3012
Car: 2003 Infiniti G35 Sedan
The drivers side power seat is not working (front-back movement) . The power backrest works fine. I get a clicking sound when i try to move the seat front or back. What might be wrong? Will i be able to fix it myself or will i have to spend big $$$
Thank you in advance.
03 - G 3557K miles
telcoman
crazyboy3012 wrote:The drivers side power seat is not working (front-back movement) . The power backrest works fine. I get a clicking sound when i try to move the seat front or back. What might be wrong? Will i be able to fix it myself or will i have to spend big $$$
03 - G 3557K miles
Check to see that nothing is caught in the track.
Its possible the seat motor died? Some of the Infiniti Shop Manuals have been previously posted on this site. You may want to try a search.
I personally have purchased Shop Manuals for every vehicle that I have purchased over the past thirty years. I always found that I eventually saved more money by doing my own generally simple repairs over the cost of the manual.
Telcoman
crazyboy3012
Telcoman, thanks a lot for replying...i'll search for the manual online.
infinititech1
if you need it work right now...best thing to do is tap with a screwdriver or lightly with a hammer on the gold part of the motor that is under the front of the seat while pushin the switch. might fix it for a while...but needs a new motor. the motor itself isn't too bad to change unless you wanna change the whole seat bottom
crazyboy3012
Thank you Infinititech!!!!
infinititech1
no problem....did that work?
joe603
Car: 2014 Durango R/T
When mine stopped working, I had the dealer fix it. It was a bad switch...
infinititech1
the switches in those cars don't go bad very often
