evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Aug 15, 2007 5:30 pm
all the bolt ons will add only minimal amounts of power, that might be enough for you, turbo and superchargers are a way to add significant amounts of power, turbo has more potential but the harder you push it the shorter the engine life, NOS is completely safe if done properly and you don't get greedy, if you keep the margins low, say max +100 hp gain, then you should be fine, but once you get to the 400 whp mark these engines don't last long, tuning is the most important thing, one ping can trash your motor, stay with quality kits and read the instructions carefully and you'll be ok
