Power question
scottsnissan
Car: 1995 240 sx se
OK i have a 91 240 no power options.
I have a 92 with power windows and mirrors.
MY question is how hard would the swap be?Do i need to do alot of wiring or what not?
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
well for starters you're going to need to change the door panels to accomodate the switches, and you're going to need to run the wiring behind/under the dash to the fuse box and to the other door, as well as the power window switch in the center console. removal of the dash shouldn't be necessary, but you should remove the kickpanels and glovebox and such to hide the wires properly. it would be a nice afternoon's work even if you're not familiar with removing your interior, but if you've never touched wiring then you might want to grab a friend who is fairly skilled. no botching the back of the fuse box. do it right and depin and repin where necessary to make it nice.
