Power Outlet--'04 Coupe
SlylyPFunkinAwaMileStoned
I'm not thread literate, so bear w/me. The answer's probably somewhere on ths page, but I'm old and can't find it. I failed to "disconnect the plug before I turned off the power switch "(pages 2-25,26) and now the 12V 120W outlet is dead on my wife's car. Everything else I can test/see on the dashboard works, including the cigarette lighter. Which fuse under the hood, controls it? Is there a fuse puller somewhere in this car small enough to pull it, cause it's smaller than what I'm used to? If it's not a fuse, is it the actual outlet?
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
fuse box is on the driver side... there is a kick panel by your left foot... should have a fuse puller and maybe some extra fuses... if not just hit up an auto parts store and get the ATM mini fuse in the right amp value...
