power or suspension
silvia R
what's more important? power or suspension? should i get a sr20det s13 droped in first or upgrade the suspinsion and wheels and tires? once again sorry if its a repost. if the suspinsion first would it make a big difference in control? what kind of suspinsion is recommened for drifting? cause dont want to spend a couple of grand for someing i dont like ya know.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Suspension, Everyone will tell you that
what’s the point of going fast if you can’t handle the power
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
first is skill
BoostFab
Car: S13cp, S13fb, S14z
power :)....don't underestimate the stock suspension...
wangless
Car: '02 MBP WRX
dont forget the brakes
180fan
Car: 89 fastback
stock suspension can take the stock sr without a problem. best part for suspension should be tires. get the sr and some grippy tires and you'll have a good time. FYI, there's no such thing as one more important than the other, the key is balance especially when you say you want to setup something for drift.
wangless
Car: '02 MBP WRX
Quote »FYI, there's no such thing as one more important than the other, the key is balance[/quote] nicely said
SpeeDDrifT
Car: drive. drift. drive....um drift...SAFELY. k
i agree with D1sr240 and 180fan.....however i would go for suspension first....especially in your case....you are a newbie drifter and the KA will provide sufficient power for learning. a good suspension set-up with communicate much more to the driver than a stock set-up.....anyone that has invested in a good suspension set-up will agree with that. and reason number two the suspension can be had for less $$$....if your planning on doing the motor right.
my reccomendation is Tein...(HE coilovers and adjustable tie rods is a good start)..cuz i'm a tein freak.......but it is really preference.....so do some research...and you will have a better understanding of what you need or want to fit your specifications.
a QUALITY suspension will make your car a whole different experience (as would a motor)
if drifting is your goal.....get a LSD along with the suspension
silvia R
ok thanks, some good info :cool:
Kaioshin1982
Car: Not a 240 =) Thinking of getting one again...
if your looking for some fun while cruising around, I say power, if you want to have fun drifting, I would also say suspension and lsd first.
Ghettokracker71
Power is no good without control.
I would also reccomend a brake upgrade. Should be a tuning law;more power means better brakes.
POS_S13
Car: thizzlamics
both, what fun is it to have thousands of dollars worth of multi links and no power. to start i would go with some coils and an lsd. then go from there. as for brakes since you're startin out just get some nice pads/ ss lines/ and slotted rotors.
marshun
suspension. you dont need allot of power to drift.
theburg240SX
Car: girls,drifting,and cars
Get the sr20 swap and then get coilovers and LSD. That the path I am taking.
BuudWeizErr
if you want to drift...
GET AN LSD!!!!and a pair or two of junkyard wheels and tires for them.
everything after that, upgrade it as your skill increases.
