Hello, I am new to this group.
I need help with a power issue. I purchased a 93 2+2 Non Turbo as is for $1000, and it needed work...
Well after alot of work (timing belt. drive belts, heat core, AC complete, CAS) it starts within 5 turns and drops to idle at 750 to 900 rpm's.
As soon as accessories are added ( full load) rpm's drop below 500 and struggle to recover. Most noticeable with AC and Defrost. Checked all connections Vac hoses.
Checked output voltage at Batt terminal (positive side) 14.1-14.11 without accessory load, output with load 12.8v and drops to 12.24 with full load.
Note: TPS set to .45-.46v , and was only able to achieve 1k ohm at full accelerator release with adjustment.
Also Note: CAS setting not Timing light calibrated.
In gear rpm's drop to 600 without load and stalls (sometimes) with load.
Could alternator be failing.
