hey guys im new to the forum and have been searching for a fix since i got my Zed 3 weeks ago... i got the car missing on cyl 3 and quickly put that down to an injector failing so i got myself a spare motor because 300 bucks for a whoel motor was better then 350 for 1 injector... replace the injector and the miss went away ...yay.... i was so excited i took the zed for a skid :o it was amazing UNTIL it hit half way on the temp gague
it was boggy and slow after that and just felt like it had no tourque ... i fiddle with things for a couple of hours with no change so i left it... the next day i was on my way to get some vasso to spank the monkey persay and it went hard! UNTIL it hit half on the temp gague again so basically power loss when warm things i have tried....
*new spark plugs
*MAF clean
*02 sensor change
*checked the coolant temp sensors
* cleaned as many of that sensor plugs as i could get to with a good contact cleaner
* checked for error codes on the ecu manually and using DATASCAN 55s all round yay...
*moved the ptu up front even tbough its an S2
*checked timing and set it to factory
a few more things that i cant remember
*new air filters
other things i think it could be
*AAC?
*fuel temp sensor?
*fuel filter?
*fuel presure
i have just about had it with the car its been racking my brain for 3 weeks anfo helpful info is much appreciated
ALSO the car is smashing through fuel... uaing about 25 Liter per 100ks.... i dont own BP i cant afford to run that... also the promblem iant as bad when the weather is cold....
sorry about the long read i tried to make it a little interesting haha
cheers...
